xTaskGetApplicationTaskTag
xTaskGetApplicationTaskTagFromISR
[Task Control]
task. h
TaskHookFunction_t xTaskGetApplicationTaskTag( TaskHandle_t xTask );
TaskHookFunction_t xTaskGetApplicationTaskTagFromISR( TaskHandle_t xTask );
configUSE_APPLICATION_TASK_TAG must be defined as 1 for these functions to be available.
See the RTOS Configuration documentation for more information.
xTaskGetApplicationTaskTagFromISR() is a version of xTaskGetApplicationTaskTag() that
can be called from an interrupt service routine (ISR).
Returns the 'tag' value associated with a task. The meaning and use of the tag
value is defined by the application writer. The RTOS kernel itself will not normally
access the tag value.
- Parameters:
xTask | The handle of the task being queried. A task can query its own tag value by using NULL as the parameter value. |
The 'tag' value of the task being queried.
/* In this example, an integer is set as the task tag value. */
void vATask( void *pvParameters )
/* Assign a tag value of 1 to the currently executing task.
The (void *) cast is used to prevent compiler warnings. */
vTaskSetApplicationTaskTag( NULL, ( void * ) 1 );
for( ;; )
/* Rest of task code goes here. */
void vAFunction( void )
TaskHandle_t xHandle;
int iReturnedTaskHandle;
/* Create a task from the vATask() function, storing the handle to the
created task in the xTask variable. */
/* Create the task. */
if( xTaskCreate(
vATask, /* Pointer to the function that implements
the task. */
"Demo task", /* Text name given to the task. */
STACK_SIZE, /* The size of the stack that should be created
for the task. This is defined in words, not
bytes. */
NULL, /* The task does not use the
parameter. */
TASK_PRIORITY, /* The priority to assign to the newly created
task. */
&xHandle /* The handle to the task being created will be
placed in xHandle. */
) == pdPASS )
/* The task was created successfully. Delay for a short period to allow
the task to run. */
vTaskDelay( 100 );
/* What tag value is assigned to the task? The returned tag value is
stored in an integer, so cast to an integer to prevent compiler
warnings. */
iReturnedTaskHandle = ( int ) xTaskGetApplicationTaskTag( xHandle );
