xSemaphoreTakeRecursive
[Semaphores]
semphr. h
xSemaphoreTakeRecursive( SemaphoreHandle_t xMutex, TickType_t xTicksToWait );
Macro to recursively obtain, or 'take', a mutex type semaphore. The mutex must have previously been created using a call to xSemaphoreCreateRecursiveMutex();
configUSE_RECURSIVE_MUTEXES must be set to 1 in FreeRTOSConfig.h for this macro to be available.
A mutex used recursively can be 'taken' repeatedly by the owner. The mutex doesn't become available again until the owner has called xSemaphoreGiveRecursive() for each successful 'take' request. For example, if a task successfully 'takes' the same mutex 5 times then the mutex will not be available to any other task until it has also 'given' the mutex back exactly five times.
xMutex A handle to the mutex being obtained. This is the handle returned by xSemaphoreCreateRecursiveMutex().
xTicksToWait The time in ticks to wait for the semaphore to become available. The macro portTICK_PERIOD_MS can be used to convert this to a real time. A block time of zero can be used to poll the semaphore. If the task already owns the semaphore then xSemaphoreTakeRecursive() will return immediately no matter what the value of xTicksToWait.
pdTRUE if the semaphore was obtained. pdFALSE if xTicksToWait expired without the semaphore becoming available.
    // ... Do other things.
    if( xMutex != NULL )
        // See if we can obtain the mutex.  If the mutex is not available
            // shared resource.
            // xSemaphoreTakeRecursive() are made on the same mutex.  In real
            // no sense.  Instead the calls are likely to be buried inside
            // three times.  Again it is unlikely that real code would have
            // these calls sequentially, but instead buried in a more complex
            // call structure.  This is just for illustrative purposes.
