xSemaphoreGiveRecursive
[Semaphores]
semphr. h
xSemaphoreGiveRecursive( SemaphoreHandle_t xMutex )
Macro to recursively release, or 'give', a mutex type semaphore. The mutex must have previously been created using a call to xSemaphoreCreateRecursiveMutex();
configUSE_RECURSIVE_MUTEXES must be set to 1 in FreeRTOSConfig.h for this macro to be available.
A mutex used recursively can be 'taken' repeatedly by the owner. The mutex doesn't become available again until the owner has called xSemaphoreGiveRecursive() for each successful 'take' request. For example, if a task successfully 'takes' the same mutex 5 times then the mutex will not be available to any other task until it has also 'given' the mutex back exactly five times.
xMutex A handle to the mutex being released, or 'given'. This is the handle returned by xSemaphoreCreateRecursiveMutex().
pdTRUE if the semaphore was successfully given.
    // ... Do other things.
    if( xMutex != NULL )
        // See if we can obtain the mutex.  If the mutex is not available
            // shared resource.
            // xSemaphoreTakeRecursive() are made on the same mutex.  In real
            // no sense.  Instead the calls are likely to be buried inside
            // three times.  Again it is unlikely that real code would have
            // these calls sequentially, it would be more likely that the calls
            // to xSemaphoreGiveRecursive() would be called as a call stack
            // unwound.  This is just for demonstrative purposes.
