xSemaphoreCreateCountingStatic
[Semaphores]
semphr. h
SemaphoreHandle_t xSemaphoreCreateCountingStatic(
UBaseType_t uxMaxCount,
UBaseType_t uxInitialCount
StaticSemaphore_t *pxSemaphoreBuffer ); );
Creates a counting semaphore
and returns a handle by which the newly created semaphore can be referenced.
must be set to 1 in FreeRTOSConfig.h for this RTOS API function to be available.
Each counting semaphore require a small amount of RAM that is used to hold the
semaphore’s state. If a counting semaphore is created using xSemaphoreCreateCounting()
If a counting semaphore is created using xSemaphoreCreateCountingStatic()
time. See the Static Vs
Counting events.
In this usage scenario an event handler will ‘give’ a semaphore each time
an event occurs (incrementing the semaphore count value), and a handler
task will ‘take’ a semaphore each time it processes an event
(decrementing the semaphore count value). The count value is therefore
the difference between the number of events that have occurred and the
number that have been processed. In this case it is desirable for the
initial count value to be zero.
Note the same functionality can often be achieved in a more efficient way
using a direct to task notification.
Resource management.
In this usage scenario the count value indicates the number of resources
available. To obtain control of a resource a task must first obtain a
semaphore – decrementing the semaphore count value. When the count value
reaches zero there are no free resources. When a task finishes with the
resource it ‘gives’ the semaphore back – incrementing the semaphore count
value. In this case it is desirable for the initial count value to be
equal to the maximum count value, indicating that all resources are free.
uxMaxCount
The maximum count value that can be reached. When the semaphore reaches this value it can no longer be ‘given’.
uxInitialCount
The count value assigned to the semaphore when it is created.
pxSemaphoreBuffer
Must point to a variable of type StaticSemaphore_t, which is
then used to hold the semaphore’s data structures.
If the semaphore is created successfully then a handle to the semaphore
is returned. If pxSemaphoreBuffer is NULL then NULL is returned.
static StaticSemaphore_t xSemaphoreBuffer;
SemaphoreHandle_t xSemaphore;
/* Create a counting semaphore that has a maximum count of 10 and an
initial count of 0. The semaphore's data structures are stored in the
xSemaphoreBuffer variable - no dynamic memory allocation is performed. */
xSemaphore = xSemaphoreCreateCountingStatic( 10, 0, &xSemaphoreBuffer );
/* pxSemaphoreBuffer was not NULL so it is expected that the semaphore
will be created. */
configASSERT( xSemaphore );
