queue.h
BaseType_t xQueueGetStaticBuffers( QueueHandle_t xQueue,
uint8_t ** ppucQueueStorage,
StaticQueue_t ** ppxStaticQueue );
Retrieve pointers to a statically created queue's data structure buffer and storage area buffer. These are the same buffers that are supplied at the time of creation.
xQueue
The queue whose data structure buffer and storage area buffer will be retrieved.
ppucQueueStorage
Used to return a pointer to the queue's storage area buffer.
ppxStaticQueue
Used to return a pointer to the queue's data structure buffer.
