xMessageBufferSendFromISR()
[RTOS Message Buffer API]
message_buffer.h
size_t xMessageBufferSendFromISR( MessageBufferHandle_t xMessageBuffer,
                                  const void *pvTxData,
                                  size_t xDataLengthBytes,
Interrupt safe version of the API function that sends a discrete message to the message buffer. The message can be any length that fits within the buffer’s free space, and is copied into the buffer.
Use xMessageBufferSend() to write to a message buffer from a task. Use xMessageBufferSendFromISR() to write to a message buffer from an interrupt service routine (ISR).
xMessageBuffer   The handle of the message buffer to which a message is being sent.
pvTxData   A pointer to the message that is to be copied into the message buffer.
xDataLengthBytes   The length of the message. That is, the number of bytes to copy from pvTxData into the message buffer. When a message is written to the message buffer an additional sizeof( size_t ) bytes are also written to store the message’s length. sizeof( size_t ) is typically 4 bytes on a 32-bit architecture, so on most 32-bit architecture setting xDataLengthBytes to 20 will reduce the free space in the message buffer by 24 bytes (20 bytes of message data and 4 bytes to hold the message length).
pxHigherPriorityTaskWoken   It is possible that a message buffer will have a task blocked on it waiting for data. Calling xMessageBufferSendFromISR() can make data available, and so cause a task that was waiting for data to leave the Blocked state. If calling xMessageBufferSendFromISR() causes a task to leave the Blocked state, and the unblocked task has a priority higher than the currently executing task (the task that was interrupted), then, internally, xMessageBufferSendFromISR() will set *pxHigherPriorityTaskWoken to pdTRUE. If xMessageBufferSendFromISR() sets this value to pdTRUE, then normally a context switch should be performed before the interrupt is exited. This will ensure that the interrupt returns directly to the highest priority Ready state task. *pxHigherPriorityTaskWoken should be set to pdFALSE before it is passed into the function. See the code example below for an example.
The number of bytes actually written to the message buffer. If the message buffer didn’t have enough free space for the message to be stored then 0 is returned, otherwise xDataLengthBytes is returned.
size_t xBytesSent;
    /* Attempt to send the string to the message buffer. */
    xBytesSent = xMessageBufferSendFromISR( xMessageBuffer,
                                            ( void * ) pcStringToSend,
                                            strlen( pcStringToSend ),
                                            &xHigherPriorityTaskWoken );
        /* The string could not be added to the message buffer because there was
        not enough free space in the buffer. */
    xMessageBufferSendFromISR() then a task that has a priority above the
