xMessageBufferReceiveFromISR()
[RTOS Message Buffer API]
message_buffer.h
size_t xMessageBufferReceiveFromISR( MessageBufferHandle_t xMessageBuffer,
                                     void *pvRxData,
                                     size_t xBufferLengthBytes,
An interrupt safe version of the API function that receives a discrete message from a message buffer. Messages can be of variable length and are copied out of the buffer.
pvRxData   A pointer to the buffer into which the received message will be copied.
pxHigherPriorityTaskWoken   (This is an optional parameter that can be set to NULL.) It is possible that a message buffer will have a task blocked on it waiting for space to become available. Calling xMessageBufferReceiveFromISR() can make space available, and so cause a task that is waiting for space to leave the Blocked state. If calling xMessageBufferReceiveFromISR() causes a task to leave the Blocked state, and the unblocked task has a priority higher than the currently executing task (the task that was interrupted), then, internally, xMessageBufferReceiveFromISR() will set *pxHigherPriorityTaskWoken to pdTRUE. If xMessageBufferReceiveFromISR() sets this value to pdTRUE, then normally a context switch should be performed before the interrupt is exited. That will ensure the interrupt returns directly to the highest priority Ready state task. *pxHigherPriorityTaskWoken should be set to pdFALSE before it is passed into the function. See the code example below for an example.
The length, in bytes, of the message read from the message buffer, if any.
MessageBuffer_t xMessageBuffer;
uint8_t ucRxData[ 20 ];
size_t xReceivedBytes;
    /* Receive the next message from the message buffer. */
    xReceivedBytes = xMessageBufferReceiveFromISR( xMessageBuffer,
                                                  ( void * ) ucRxData,
                                                  sizeof( ucRxData ),
                                                  &xHigherPriorityTaskWoken );
    if( xReceivedBytes > 0 )
        the message here.... */
    xMessageBufferReceiveFromISR() then a task that has a priority above the
