message_buffer.h
BaseType_t xMessageBufferIsFull( MessageBufferHandle_t xMessageBuffer );
Queries a message buffer to see if it is full.
A message buffer is full if it cannot accept any more messages, of any size,
until space is made available by a message being removed from the message buffer.
xMessageBuffer
The handle of the message buffer being queried.
If the message buffer is full then pdTRUE is returned. Otherwise
pdFALSE is returned.
