uxTaskGetSystemState()
[Task Utilities]
task.h
UBaseType_t uxTaskGetSystemState(
                       TaskStatus_t * const pxTaskStatusArray,
                       const UBaseType_t uxArraySize,
                       unsigned long * const pulTotalRunTime );
configUSE_TRACE_FACILITY must be defined as 1 in FreeRTOSConfig.h for uxTaskGetSystemState() to be available.
uxTaskGetSystemState() populates an TaskStatus_t structure for each task in the system. TaskStatus_t structures contain, among other things, members for the task handle, task name, task priority, task state, and total amount of run time consumed by the task.
See vTaskGetInfo() for a version that populates a TaskStatus_t structure for a single task, instead of every task.
NOTE: This function is intended for debugging use only as its use results in the scheduler remaining suspended for an extended period.
pxTaskStatusArray   A pointer to an array of TaskStatus_t structures. The array must contain at least one TaskStatus_t structure for each task that is under the control of the RTOS. The number of tasks under the control of the RTOS can be determined using the uxTaskGetNumberOfTasks() API function.
uxArraySize   The size of the array pointed to by the pxTaskStatusArray parameter. The size is specified as the number of indexes in the array (the number of TaskStatus_t structures contained in the array), not by the number of bytes in the array.
pulTotalRunTime   If configGENERATE_RUN_TIME_STATS is set to 1 in FreeRTOSConfig.h then *pulTotalRunTime is set by uxTaskGetSystemState() to the total run time (as defined by the run time stats clock) since the target booted. pulTotalRunTime can be set to NULL to omit the total run time value.
The number of TaskStatus_t structures that were populated by uxTaskGetSystemState(). This should equal the number returned by the uxTaskGetNumberOfTasks() API function, but will be zero if the value passed in the uxArraySize parameter was too small.
/* This example demonstrates how a human readable table of run time stats
information is generated from raw data provided by uxTaskGetSystemState().
The human readable table is written to pcWriteBuffer.  (see the vTaskList()
API function which actually does just this). */
void vTaskGetRunTimeStats( signed char *pcWriteBuffer )
TaskStatus_t *pxTaskStatusArray;
volatile UBaseType_t uxArraySize, x;
unsigned long ulTotalRunTime, ulStatsAsPercentage;
   /* Make sure the write buffer does not contain a string. */
   *pcWriteBuffer = 0x00;
   /* Take a snapshot of the number of tasks in case it changes while this
   function is executing. */
   uxArraySize = uxTaskGetNumberOfTasks();
   /* Allocate a TaskStatus_t structure for each task.  An array could be
   allocated statically at compile time. */
   pxTaskStatusArray = pvPortMalloc( uxArraySize * sizeof( TaskStatus_t ) );
   if( pxTaskStatusArray != NULL )
      /* Generate raw status information about each task. */
      uxArraySize = uxTaskGetSystemState( pxTaskStatusArray,
                                 uxArraySize,
                                 &ulTotalRunTime );
      /* For percentage calculations. */
      ulTotalRunTime /= 100UL;
      /* Avoid divide by zero errors. */
      if( ulTotalRunTime > 0 )
         /* For each populated position in the pxTaskStatusArray array,
         format the raw data as human readable ASCII data. */
         for( x = 0; x < uxArraySize; x++ )
            /* What percentage of the total run time has the task used?
            This will always be rounded down to the nearest integer.
            ulTotalRunTimeDiv100 has already been divided by 100. */
            ulStatsAsPercentage =
                  pxTaskStatusArray[ x ].ulRunTimeCounter / ulTotalRunTime;
            if( ulStatsAsPercentage > 0UL )
               sprintf( pcWriteBuffer, "%stt%lutt%lu%%rn",
                                 pxTaskStatusArray[ x ].pcTaskName,
                                 pxTaskStatusArray[ x ].ulRunTimeCounter,
                                 ulStatsAsPercentage );
               /* If the percentage is zero here then the task has
               consumed less than 1% of the total run time. */
               sprintf( pcWriteBuffer, "%stt%lutt<1%%rn",
                                 pxTaskStatusArray[ x ].ulRunTimeCounter );
            pcWriteBuffer += strlen( ( char * ) pcWriteBuffer );
      /* The array is no longer needed, free the memory it consumes. */
      vPortFree( pxTaskStatusArray );
The TaskStatus_t definition
typedef struct xTASK_STATUS
   /* The handle of the task to which the rest of the information in the
   structure relates. */
   TaskHandle_t xHandle;
   /* A pointer to the task's name.  This value will be invalid if the task was
   deleted since the structure was populated! */
   const signed char *pcTaskName;
   /* A number unique to the task. */
   UBaseType_t xTaskNumber;
   /* The state in which the task existed when the structure was populated. */
   eTaskState eCurrentState;
   /* The priority at which the task was running (may be inherited) when the
   UBaseType_t uxCurrentPriority;
   /* The priority to which the task will return if the task's current priority
   has been inherited to avoid unbounded priority inversion when obtaining a
   mutex.  Only valid if configUSE_MUTEXES is defined as 1 in
   FreeRTOSConfig.h. */
   UBaseType_t uxBasePriority;
   /* The total run time allocated to the task so far, as defined by the run
   time stats clock.  Only valid when configGENERATE_RUN_TIME_STATS is
   defined as 1 in FreeRTOSConfig.h. */
   unsigned long ulRunTimeCounter;
   /* Points to the lowest address of the task's stack area. */
   StackType_t *pxStackBase;
   /* The minimum amount of stack space that has remained for the task since
   the task was created.  The closer this value is to zero the closer the task
   has come to overflowing its stack. */
   configSTACK_DEPTH_TYPE usStackHighWaterMark;
} TaskStatus_t;
