Targeting an Arm Corstone-3xx platform based on Arm Cortex-M MCU
This reference integration demonstrates how to develop cloud connected applications and update them
securely by integrating the modular FreeRTOS kernel and
libraries and utilizing hardware-enforced security based
on
Arm TrustZone (Armv8-M).
To utilize the hardware-enforced security, this integration uses PSA Certified reference implementation
Trusted
Firmware-M. Trusted Firmware-M provides various Secure services such as Secure boot, Crypto, Secure
Storage, Attestation and Update services meeting
PSA Certified requirements. This integration is based on the
Corstone-300
platform.
Developers and partners can use this integration as a starting point to build the FreeRTOS kernel and
libraries-based software stack on top of Arm Cortex-M based platforms. All the components are put together
in a modular manner to make porting this integration across platforms easy.
Demonstrated security features and function
Trusted Firmware-M (TF-M) leverages the Arm TrustZone technology to provide a Non-Secure Processing Environment
(NSPE) and a Secure Processing Environment (SPE) which are isolated from each other. The FreeRTOS kernel,
middleware and application run in the NSPE while TF-M runs in the SPE. TF-M provides the PSA RoT secure services
through the PSA Certified Functional APIs to the NSPE. The isolation ensures TF-M code, assets (keys, certificates,
and so on) and data are protected from any vulnerabilities present in the NSPE.
The demo showcases how a Secure TLS connection between the Corstone-300 and AWS IoT Core can be established making
use of the TF-M's PSA Crypto and Secure Storage functions. In addition, it demonstrates a secure OTA update of the
platform using TF-M's Firmware Update Service.
Secure TLS Connection
The Corstone-300 communicates with AWS IoT Core over a secure TLS connection. Mbed TLS running on the NSPE is used
to establish the TLS connection. Mbed TLS makes use of the PSA Crypto APIs provided by TF-M to perform Crypto
operations and PKCS#11 APIs to perform TLS client authentication and import the
TLS client certificate and private key into the device.
PKCS#11 has been integrated with TF-M using a thin shim. In the integration, the PKCS#11 APIs invoke the appropriate
PSA Secure Storage API or Cryptographic API via the shim. This ensures the keys and certificates are protected and
the cryptographic operations are performed securely within the SPE of TF-M and are isolated from the kernel,
libraries, and applications in the Non-secure Processing Environment. Keys and certificates are securely stored.
This is enabled by TF-M's Internal Trusted Storage (ITS) and Protected Storage (PS) services. Signing during TLS
client authentication is performed by TF-M's Crypto service.
Secure OTA Updates
The FreeRTOS OTA Agent provides an OTA PAL layer for platforms to integrate and enable OTA updates. The demo integrates
an OTA PAL implementation that makes use of the PSA Certified Firmware Update API that is implemented in TF-M. This
allows the Corstone-300 to receive a new image from AWS IoT Core, authenticate it using TF-M, before deploying it
as the active image. The secure (TF-M) and the non-secure (FreeRTOS kernel and application) images can be updated
separately.
Every time the device boots, MCUBoot (the bootloader) verifies that the image signature is valid before it boots
the image. Since the secure (TF-M) and the non-secure (FreeRTOS kernel and application) images are signed separately,
MCUBoot verifies that both image signatures are valid before it boots. If either of the verification fails, then
MCUBoot stops the booting process.
Memory safety proofs
The "core" FreeRTOS libraries comply with documented code quality criteria, including memory safety proofs that run
on each code check-in.
Getting started with the demo
There are two examples: "blinky" and "aws-iot-example". The "blinky" example demonstrates FreeRTOS
kernel and TF-M integration, whereas the "aws-iot-example" demonstrates connectivity to AWS IoT core
using the coreMQTT-agent library and secure OTA using the
OTA agent. The source code and the getting started guide can be found at
FreeRTOS/iot-reference-arm-corstone3xx on GitHub.
