ST ARM Cortex-M7 STM32 F7 RTOS Demo
With projects for the IAR and ARM Keil Embedded Compilers
This page provides documentation for the FreeRTOS demo that targets the STM32756G-EVAL Evaluation Kit, which incorporates an STM32F7 ARM Cortex-M7 microcontroller from STMicroelectronics. Pre-configured build projects are provided for both the IAR and ARM Keil tools.
IMPORTANT! Notes on using the STM32F7 Cortex-M7 RTOS demo
The FreeRTOS distribution available from this site contains the source files for all the FreeRTOS ports, and the projects for all the FreeRTOS demo applications. It therefore contains many more files than are required to use the STM32 F7 microcontroller. See the Source Code Organization section for a description of the directory structure and information on creating a new FreeRTOS project.
The IAR Embedded Workbench for ARM workspace for the STM32F7 demo application is called RTOSDemo.eww, and is located in the FreeRTOS/Demo/CORTEX_M7_STM32F7_STM32756G-EVAL directory.
The ARM Keil project for the STM32F7 demo application is called RTOSDemo.uvprojx, and is located in the FreeRTOS/Demo/CORTEX_M7_STM32F7_STM32756G-EVAL directory.
The ST ARM Cortex-M7 Demo Application
Hardware Setup
The demo uses an LED that is connected to port F pin 10 by positioning jumper JP24 so the jumper is connecting pin 2 to pin 3.
jumper setting to connect LED to Cortex-M7 device
JP24 is used to connect pin F10 to the LED
The STM32 F7 demo application can be built to create either a simple blinky demo, or a comprehensive test and demo application. The constant mainCREATE_SIMPLE_BLINKY_DEMO_ONLY, which is defined at the top of main.c, is used to switch between the two.
To build the simple blinky demo set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to 1, which results in main() calling main_blinky(). main_blinky() creates a simple demo as follows:
    main_blinky() creates two tasks and one queue before starting the RTOS scheduler.
    The queue send task is implemented by prvQueueSendTask() in main_blinky.c. It writes to the queue every 200 milliseconds.
    The queue receive task is implemented by prvQueueReceiveTask() in main_blinky.c. It blocks on queue reads to wait for messages from the queue send task - toggling an LED each time a message is received. As the queue send task writes to the queue every 200 milliseconds the queue receive task receives a message and toggles the LED every 200 milliseconds.
To build the comprehensive test and demo set mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to 0, which results in main() calling main_full(). The comprehensive test and demo application demonstrates: Most of the created tasks are from the set of standard demo tasks, which have no specific purpose other than to demonstrate how to use the FreeRTOS API, and to test the RTOS port.
A 'check' task is also created which periodically inspects the standard demo tasks to ensure they are executing as expected. The check task also toggles an LED. The LED will toggle every 3 seconds if the check task has determined the demo is executing as expected, and every 200ms if the check task has detected a potential error in any of the standard demo tasks.
  1. Open FreeRTOS/Demo/CORTEX_M7_STM32F7_STM32756G-EVAL/RTOSDemo.eww from within the IAR Embedded Workbench IDE.
  3. Ensure the target hardware is connected to the host computer using a suitable debugger interface - the demo was developed and debugged using a J-Link.
  4. Select 'Rebuild All' from the IDE's 'Project' menu, the RTOSDemo project should build without any errors or warnings.
  5. After the build completes, select 'Download and Debug' from the IDE's 'Project' menu to program the Cortex-M7 microcontroller, start a debug session, and have the debugger break on entry into the main() function.
Building and executing the demo application - Keil
  1. Open FreeRTOS/Demo/CORTEX_M7_STM32F7_STM32756G-EVAL/RTOSDemo.uvprojx from within the Keil uVision IDE.
  4. Select 'Build Target' from the IDE's 'Project' menu, the RTOSDemo project should build without any errors or warnings.
  5. After the build completes, select "Start/Stop Debug Session" from the IDE's 'Debug' menu to program the Cortex-M7 microcontroller, start a debug session, and have the debugger break on entry into the main() function.
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_M7_STM32F7_STM32756G-EVAL/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
    Whereas configKERNEL_INTERRUPT_PRIORITY and configMAX_SYSCALL_INTERRUPT_PRIORITY are full eight bit un-shifted values, defined to be used as raw numbers directly in the ARM Cortex-M7 NVIC registers, configLIBRARY_LOWEST_INTERRUPT_PRIORITY and configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY are equivalents that are defined using just the 4 priority bits implemented in the STM32F7 NVIC. These values are provided because the CMSIS library function NVIC_SetPriority() requires the un-shifted 4 bit format.
It is also recommended to ensure that all priority bits are assigned as being preemption priority bits, and none as sub priority bits as is done in the demo project by the function call
