FreeRTOS for Renesas RX231 (RXv2)
Renesas RX231 RXv2 core
This page documents the RTOS demo applications that targets the Renesas RX231 family of microcontrollers, which have an RXv2 core.
Three projects are provided:
All three projects include build options that allow the creation of a simple blinky demo or a comprehensive demo, and target the RX231 RSK (Renesas Start Kit) evaluation board.
IMPORTANT! Notes on using the RX231 RTOS demo projects
The FreeRTOS download contains the source code for all the RTOS ports, so contains lots more files than are required by the RX231 projects. See the Source Code Organization section of this website for more information.
The IAR project is called RTOSDemo.eww, and is located in the /FreeRTOS/Demo/RX200_RX231-RSK_GCC_e2studio_IAR directory.
The e2studio projects have the usual Eclipse project name .project. The project that uses the GCC compiler is also located in the /FreeRTOS/Demo/RX200_RX231-RSK_GCC_e2studio_IAR directory, and the project that uses the Renesas compiler is located in the /FreeRTOS/Demo/RX200_RX231-RSK_Renesas_e2studio directory. These are the directories that must be selected when importing the projects into the e2studio Eclipse workspace.
Building and Running the Renesas RX231 RTOS Demo
The RTOS demo projects can be configured to build either a simple blinky application, or a comprehensive test and demo application. The constant mainCREATE_SIMPLE_BLINKY_DEMO_ONLY, which is defined at the top of main.c, is used to switch between the two. The comprehensive project is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0. The simple demo is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1.
The demos use an LED built onto the RSK development board, so no hardware set up is required.
    Importing the RX64M project into the e2studio Eclipse IDE
  3. In the next dialogue box, select /FreeRTOS/Demo/RX200_RX231-RSK_GCC_e2studio_IAR as the root directory if you are using the GCC compiler, or /FreeRTOS/Demo/RX200_RX231-RSK_Renesas_e2studio if you are using the Renesas compiler.
  7. Ensure the E1 debug adapter (which comes with the RSK starter kit) is connected between the RX231 RSK board and the computer running e2studio. If you configure the launch configurations as per the images below then there is no need for a separate power supply.
    Click images to enlarge
The simply blinky example
The comprehensive example is created when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0 in main.c. When this is done, main() calls main_full():
  • The main_full() Function:
    main_full() creates a set of standard demo tasks, some application specific test tasks, a pseudo randomiser task, and then starts the scheduler. The pseudo randomiser task is just used to ensure some variation is added to the sequence in which the test tasks execute, and in so doing, improve the test coverage.
  • The "Reg Test" Tasks:
  • The "Check" Task:
RX231 RTOS port specific configuration
Configuration items specific to this demo are contained in /FreeRTOS/Demo/RX200_RX231-RSK_GCC_e2studio_IAR/src/FreeRTOSConfig.h for the IAR and GCC projects, and /FreeRTOS/Demo/RX200_RX231-RSK_Renesas_e2studio/src/FreeRTOSConfig.h for the Renesas compiler project. The constants defined in these files can be edited to suit your application. In particular -
    This defines the interrupt priority used by the RTOS kernel for the RTOS tick timer and software interrupts. This should always be set to the lowest interrupt priority, which is 1 for the RX231. See the configuration pages for more information.
/* Function definition. */
    function. */
    __enable_interrupt();
    function. */
    __asm volatile( "SETPSW	I" );
    function. */
It is suggested that a compare match timer is used to generate the tick interrupt, and an example implementation of vApplicationSetupTimerInterrupt() that uses compare match timer 0 is included in main.c within each RX200 demo application.
Source/Portable/MemMang/heap_4.c is included in the RX231 demo application project to provide the memory allocation required by the RTOS kernel. Please refer to the Memory Management section of the API documentation for full information.
