RTOS Stream Buffers
[Stream Buffers and Message Buffers]
On this page:
  1. Introduction
  2. Getting started
  3. Blocking reads and Trigger Levels
  4. Blocking Writes
  5. Send and Receive Complete Macros (for multicore use)
Stream buffers allow a stream of bytes to be passed from an interrupt service routine to a task, or from one task to another task. A byte stream can be of arbitrary length and does not necessarily have a beginning or end. Any number of bytes can be written in one go, and any number of bytes can be read in one go. Data is passed by copy - the data is copied into the buffer by the sender and out of the buffer by the read.
Unlike most other FreeRTOS communications primitives, stream buffers are optimised for single reader single writer scenarios, such as passing data from an interrupt service routine to a task, or from one microcontroller core to another on a dual core CPU.
The stream buffer implementation uses direct to task notifications. Therefore, calling a stream buffer API function that places the calling task into the Blocked state can change the calling task's notification state and value.
Getting Started
The FreeRTOS/Demo/Common/Minimal/StreamBufferInterrupt.c source file provides a heavily commented example of how to use a stream buffer to pass data from an interrupt service routine to a task.
See the stream buffer section of the user documentation for a list of stream buffer related API functions, in many cases including code snippets that demonstrate the functions being used.
Blocking Reads and Trigger Levels
xStreamBufferReceive() is used to read data out of a stream buffer from an RTOS task. xStreamBufferReceiveFromISR()) is used to read data out of a stream buffer from an interrupt service routine (ISR).
xStreamBufferReceive() allows a block time to be specified. If a non zero block time is specified when a task uses xStreamBufferReceive() to read from a stream buffer that happens to be empty the task will be placed into the Blocked state (so it is not consuming any CPU time and other tasks can run) until either a specified amount of data becomes available in the stream buffer, or the block time expires. The amount of data that must be in the stream buffer before a task that is waiting for data is removed from the blocked state is called the stream buffer's Trigger Level. For example:
  • If a task is blocked on a read of an empty stream buffer that has a trigger level of 1 then the task will be unblocked when a single byte is written to the buffer or the task's block time expires.
  • If a task is blocked on a read of an empty stream buffer that has a trigger level of 10 then the task will not be unblocked until the stream buffer contains at least 10 bytes or the task's block time expires.
If a reading task's block time expires before the trigger level is reached then the task will still receive however many bytes are actually available.
Notes:
  • It is not valid to set the trigger level to 0. Attempting to set the trigger level to 0 will result result in a trigger level of 1 being used.
  • It is also not valid to specify a trigger level that is greater than the stream buffer's size.
The stream buffer's trigger level is initially set when the stream buffer is created, and can then be changed using the xStreamBufferSetTriggerLevel() API function.
Blocking Writes
xStreamBufferSend()) is used to send data to a stream buffer from an RTOS task. xStreamBufferSendFromISR()) is used to send data to a stream buffer from an interrupt service routine (ISR).
If a non zero block time is specified when a task uses xStreamBufferSend() to write to a stream buffer that happens to be full the task will be placed into the Blocked state (so it is not consuming any CPU time and other tasks can run) until either space becomes available in the stream buffer, or the block time expires.
Send Complete and Receive Complete Callbacks
[Also see the blog on using message buffers for dual core - core to core communication.]
Stream and message buffers execute a callback upon completion of each send and receive operation:
  • Stream and message buffers created using the xStreamBufferCreate() and xMessageBufferCreate() API functions (and their statically allocated equivalents) share the same callback functions, which are defined using the sbSEND_COMPLETED() and sbRECEIVE_COMPLETED() macros. The following sections provide more information on these macros.
  • Stream and message buffers created using the xStreamBufferCreateWithCallback() and xMessageBufferCreateWithCallback() API functions (and their statically allocated equivalents) can each have their own unique callback function.
sbSEND_COMPLETED() (and sbSEND_COMPLETED_FROM_ISR())
sbSEND_COMPLETED() is a macro that is called (internally within the FreeRTOS API functions) when data is written to a stream buffer created using the xStreamBufferCreate() or xStreamBufferCreateStatic() API. It takes a single parameter, which is the handle of the stream buffer that was updated.
By default (if the application writer doesn't provide their own implementation of the macro) sbSEND_COMPLETED() checks to see if there is a task blocked on the stream buffer to wait for data, and if so, removes the task from the Blocked state.
It is possible for the application writer to change this default behaviour by providing their own implementation of sbSEND_COMPLETED() in FreeRTOSConfig.h. That is useful when a stream buffer is used to pass data between cores on a multicore processor. In that scenario, sbSEND_COMPLETED() can be implemented to generate an interrupt in the other CPU core, and the interrupt's service routine can then use the xStreamBufferSendCompletedFromISR() API function to check, and if necessary unblock, a task that was waiting for the data.
The FreeRTOS/Demo/Common/Minimal/MessageBufferAMP.c source file provides a heavily commented example of exactly that scenario.
Create the stream buffer using the xStreamBufferCreateStaticWithCallback() or xStreamBufferCreateStaticWithCallback() API functions if you need each stream buffer to have its own “send completed” behaviour.
sbRECEIVE_COMPLETED() (and sbRECEIVE_COMPLETED_FROM_ISR())
sbRECEIVE_COMPLETED() is the receive equivalent of sbSEND_COMPLETED(). It is called (internally within the FreeRTOS API functions) when data is read from a stream buffer. By default (if the application writer doesn’t provide their own implementation of the macro) the macro checks to see if there is a task blocked on the stream buffer to wait for space to become available within the buffer, and if so, removes the task from the Blocked state.
Just as with sbSEND_COMPLETED(), the application writer can change the default behaviour of sbRECEIVE_COMPLETED() by providing an alternative implementation in FreeRTOSConfig.h. Create the stream buffer using the xStreamBufferCreateWithCallback() or xStreamBufferCreateStaticWithCallback() API functions if you need each stream buffer to have its own "receive completed" behaviour.
