RTOS Message Buffers
[Stream Buffers and Message Buffers]
On this page:
  1. Introduction
  2. Getting started
  3. Sizing a Message Buffer
  4. Blocking Reads and Writes
  5. Send and Receive Complete Macros (for multicore use)
Message buffers allow variable length discrete messages to be passed from an interrupt service routine to a task, or from one task to another task. For example, messages of length 10, 20 and 123 bytes can all be written to, and read from, the same message buffer. Unlike when using a stream buffer, a 10 byte message can only be read out as a 10 byte message, not as individual bytes. Message buffers are built on top of stream buffers (that is, they use the stream buffer implementation).
Data is passed through a message buffer by copy - the data is copied into the buffer by the sender and out of the buffer by the read.
Also see the definition of the configMESSAGE_BUFFER_LENGTH_TYPE configuration parameter.
Unlike most other FreeRTOS communications primitives, stream buffers, and therefore also message buffers, are optimised for single reader single writer scenarios, such as passing data from an interrupt service routine to a task, or from one microcontroller core to another on a dual core CPU.
Message buffer functionality is enabled by including the FreeRTOS/source/stream_buffer.c source file in the build.
The message buffer implementation uses direct to task notifications. Therefore, calling a message buffer API function that places the calling task into the Blocked state can change the calling task's notification state and value.
Getting Started
The FreeRTOS/Demo/Common/Minimal/MessageBufferAMP.c source file provides a heavily commented example of how to use a message buffer to pass variable length data from one MCU core to another on a multi-core MCU. That is quite an advanced scenario, but the mechanism for creating, sending to and receiving from the message buffer is the same in simpler single core scenarios where, unlike in the demo, it is not necessary to override the sbSEND_COMPLETE() macros.
See the message buffer section of the user documentation for a list of message buffer related API functions, in many cases including code snippets that demonstrate the functions being used.
To enable message buffers to handle variable sized messages the length of each message is written into the message buffer before the message itself (that happens internally with the FreeRTOS API functions). The length is stored in a variable, the type of which is set by the configMESSAGE_BUFFER_LENGTH_TYPE constant in FreeRTOSConfig.h. configMESSAGE_BUFFER_LENGTH_TYPE defaults to be of type size_t if left undefined. size_t is typically 4-bytes on a 32-bit architecture. Therefore, as an example, writing a 10 byte message into a message buffer will actually consume 14 bytes of buffer space when configMESSAGE_BUFFER_LENGTH_TYPE is 4-bytes. Likewise writing a 100 byte message into a message buffer will actually store 104 bytes of buffer space.
xMessageBufferReceive()) is used to read data from a message buffer from an RTOS task. xMessageBufferReceiveFromISR()) is used to read data from a message buffer from an interrupt service routine (ISR). xMessageBufferSend()) is used to send data to a message buffer from an RTOS task. xMessageBufferSendFromISR()) is used to send data to a message buffer from an interrupt service routine (ISR).
If a non zero block time is specified when a task uses xMessageBufferReceive() to read from a message buffer that happens to be empty the task will be placed into the Blocked state (so it is not consuming any CPU time and other tasks can run) until either data becomes available in the message buffer, or the block time expires.
If a non zero block time is specified when a task uses xMessageBufferSend() to write to a message buffer that happens to be full the task will be placed into the Blocked state (so it is not consuming any CPU time and other tasks can run) until either space becomes available in the message buffer, or the block time expires.
Send Complete and Receive Complete Macros
As message buffers are built on stream buffers the sbSEND_COMPLETE() and sbRECEIVE_COMPLETE() macros behave exactly as described on the page that describes stream buffers.
