RTOS Demo for RISC-V MiFive M2GL025 / Renode
RISC-V MiFive SiFive M2GL025
This page documents a pre-configured SoftConsole/GCC FreeRTOS project that originally targeted the MiFive RISC-V core on the Microchip (previously MicroSemi) M2GL025 Creative Board from Future Electronics. The target was switched to the Renode software emulation of the same board when the project became too large to run out of target RAM (which necessitated using the FPGA tools to program the application onto the target hardware). Renode is installed with SoftConole.
IMPORTANT! Notes on using the MiFive RISC-V port
  2. Source code organisation
  4. Building the RTOS demo application
  5. Running/debugging the RTOS demo in the Renode emulator
The FreeRTOS zip file download contains the source code for all the FreeRTOS ports, and every demo application. That means it contains many more files than are required to use the FreeRTOS Microchip (previously Microsemi) MiFive RISC-V demo. See the Source Code Organization page for information on the zip file's directory structure. The MiFive RISV-C SoftConsole project is located in the /Demo/RISC-V_Renode_Emulator_SoftConsole directory. More information is provided in the build instructions section below.
On RISC-V architectures the additional freertos_risc_v_chip_specific_extensions.h header file is used to extend the base RISC-V RTOS port to any chip specific extensions the target RISC-V chip may implement. The RISC-V core used on the M2GL025 board does not implement any registers over and above those defined by the base RISC-V architecture, and includes a CLINT. Therefore this project uses the freertos_risc_v_chip_specific_extensions.h header file from the /FreeRTOS/Source/portable/GCC/RISC-V/chip_specific_extensions/RV32I_CLINT_no_extensions directory.
The Microchip MiFive RISC-V Demo Application
    The queue send task is implemented by the prvQueueSendTask() function. The task sits in a loop sending the value 100 to the queue every 1000 milliseconds (1 emulated second when running in the Renode emulator).
    The queue receive task is implemented by the prvQueueReceiveTask() function. The task sits in a loop that blocks on attempts to read from the queue (no CPU cycles are consumed while the task is blocked), writing 'blink' to the Renode console each time the value 100 is received from the queue send task. As the queue send task writes to the queue every 1000 emulated milliseconds the queue receive task unblocks and writes to the Renode console every 1000 emulated milliseconds (which may be different to real milliseconds).
A 'check' task is created that periodically inspects the standard demo tasks (which contain self monitoring code) to ensure all the tasks are functioning as expected. The check task outputs a '.' character or error message to the Renode console each time it executes. This gives visual feedback of the system health. If the '.' appears on the console every 3 emulated seconds (which will differ from actual seconds), then the check task has not discovered any problems. If the console displays an error message then the check task has discovered a problem in one or more tasks.
To open and build the M2GL025 MiFive RISC-V project:
  1. Download and install the SoftConsole Eclipse based development tools.
  2. Start SoftConsole and either select an existing or create a new workspace when prompted.
  3. Select "Import..." from the SoftConsole 'File' menu. The Import dialog box will open.
  5. In the Import Projects dialog box, navigate to and select the FreeRTOS/Demo/RISC-V_Renode_Emulator_SoftConsole directory, and ensure the 'copy projects into workspace' check box is not checked.
  6. In the 'Projects' window of the Import Projects dialog box, select the RTOSDemo project, and click finish.
  7. Select "Build all" from the SoftConsole 'Project' menu. The project should build without any errors or warnings, outputting a file called RTOSDemo.elf.
Running the RTOS demo application in the Renode emulator
The instructions below demonstrate how to first start Renode, and then start a debug session that connects to Renode, all from within the SoftConsole IDE. The Renode emulator has shipped with SoftConsole since SoftConsole version 6.0:
  1. Select "External Tools->External Tools Configuration..." from the SoftConsole 'Run' menu. The "Create, manage and run configurations" dialog will open.
  2. This step creates a menu item in the SoftConsole IDE that, when clicked, starts the Renode emulator.
    In the "Create, manage and run configurations" dialog, double click "Program" to add a new configuration, then complete the configuration exactly as shown in the image below (click the image for a larger view). The tabs not shown in the image can be left at their default values.
    Creating a configuration that starts the Renode emulator. Click to enlarge.
  3. Click 'Run' to check the configuration starts Renode. Close the dialog once the configuration is able to start Renode successfully. Note: It is always necessary to stop Renode manually once it has been started, but for now, leave it running as it is needed in the next step.
  4. This step creates a debug launch configuration.
    Right click the "RTOSDemo_Debug_Renode.launch" file in the Eclipse project explorer, then select "Debug As->RTOSDemo_Debug_Renode" from the pop up menu. The debugger should start and connect to Renode (assuming the previous step left Renode running).
    Creating a debug launch configuration. Click to enlarge.
  5. Once the launch configuration is able to successfully start a debug session, stop the debug session again by selecting it in the Eclipse Debug view then clicking the terminate speed button (which has a red square on it), then shut down Renode by likewise selecting it in the Eclipse Debug view and clicking the terminate speed button again.
    Note: Stopping the debug session does not automatically stop Renode, and Renode must be manually stopped after each debug session. Failing to do this will result in high CPU load and the inability to start any new debug sessions.
    Terminating the debug session and Renode.
  6. Now the configuration to start Renode, and the configuration to start a debug session that connects to Renode, have both been created and tested, this step links both configurations together.
    Right click the "RTOSDemo-start-renode-emulator-and-attach.launch" file in the Eclipse project explorer, then select "Debug As->RTOSDemo-start-renode-emulator-and-attach" from the pop up menu. Renode should start, followed by the debug session that connects to Renode.
    Starting the Renode emulator and attaching the debugger
  • Configuration items specific to this demo are contained in FreeRTOS/Demo/RISC-V_Renode_Emulator_SoftConsole/FreeRTOSConfig.h. The constants defined in that file can be edited to suit your application. In particular, as the MiFive core includes a machine timer (MTIMER) configMTIME_BASE_ADDRESS and configMTIMECMP_BASE_ADDRESS are defined to 0xBFF8 and 0x4000 respectively, where PRCI_BASE is the base address of the clint as defined in the Microchip (previously Microsemi) SDK.
  • The MiFive core does not include any registers over and above those defined by the base RISC-V architecture. The project therefore uses the freertos_risc_v_chip_specific_extensions.h header file located in the /FreeRTOS/Source/portable/GCC/RISC-V/chip_specific_extensions/RV32I_CLINT_no_extensions directory, so that directory is in the assembler's include path.
  • The interrupt handler provided in the MiFive software development kit (SDK) is called handle_m_ext_interrupt, so the assembler's command line options include -DportasmHANDLE_INTERRUPT=handle_m_ext_interrupt.
  • The file microsemi-riscv-renode.ld is a version of the linker script provided with the board, edited to add the __freertos_irq_stack_top linker variable necessary to ensure the stack that was used by main before the scheduler starts is reused as the interrupt stack after the scheduler starts.
Other notes:
