Using GCC and the Atollic development tools
Infineon XMC4500 Hexagon Development Kit CPU board
This page documents a demo application that uses the FreeRTOS GCC ARM Cortex-M4F port. It targets the Infineon XMC4000 Hexagon Development Kit CPU board, which is populated with an XMC4500 microcontroller.
To use the port, the hardware floating point unit (the FPU, or VFP) must be switched on, and the GCC compile time options must be set to generate hardware floating point instructions. The FreeRTOS port layer will itself turn the FPU on immediately before the RTOS scheduler is started, and the pre-configured demo application described on this page has all the required compiler options.
The project can be configured to create either a basic blinky style demo, or a more comprehensive test and demo application.
IMPORTANT! Notes on using the FreeRTOS GCC XMC4000 demo project
The Eclipse project file for this demo application is located in the FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_GCC_Atollic directory. The Preparing the Eclipse Project section of this page contains important information on setting up the demo project directory, and importing the demo project into the Atollic IDE.
The single Ecplise project provides two configurations. It can be configured as a simple blinky style project, or a more comprehensive test and demo application. The mainCREATE_SIMPLE_BLINKY_DEMO_ONLY definition, located at the top of main.c, is used to switch between the two at compile time.
Setting mainCREATE_SIMPLE_BLINKY_DEMO_ONLY to 0 results in main() calling main_full(). main_full() sets up a comprehensive test and demo, which demonstrates:
  • Software timers.
  • Semaphores.
  • Mutexes.
  • Queues.
A 'check' software timer is created that periodically inspects the standard demo tasks, and register test tasks, to ensure all the tasks are functioning as expected. The check software timer's callback function toggles the single user LED on the XMC4500 Hexagon development kit CPU board. This gives a visual feedback of the system health. If the LED is toggling every 3 seconds, then the check software timer has not discovered any problems. If the LED is toggling every 200 milliseconds, then the check software timer has discovered a problem in one or more tasks.
Eclipse projects can be either standard makefile projects, or managed make projects. The FreeRTOS Atollic ARM Cortex-M4F project uses a managed make project. This in turn means that either:
Option 1 is used for this demo. Therefore, the directory FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_GCC_Atollic contains a batch file called CreateProjectDirectoryStructure.bat that copies all the required FreeRTOS source files, and some standard demo application files, into sub directories inside the demo project directory.
CreateProjectDirectoryStructure.bat must be executed before the Atollic project is imported into the Eclipse workspace.
CreateProjectDirectoryStructure.bat cannot be executed from within the Atollic IDE.
Importing the demo application into the Atollic Eclipse workspace
  1. Select "Import" from the Atollic "File" menu. The dialogue box shown below will appear. Select "Existing Projects into Workspace".
  2. In the next dialogue box, select FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_GCC_Atollic as the root directory. Then, make sure the RTOSDemo (rather than "FreeRTOS-Simple-Demo", as depicted below) project is checked in the "Projects" area, and that the Copy Projects Into Workspace box is not checked, before clicking the Finish button (see the image below for the correct check box states).
    Selecting the ARM Cortex-M4 RTOSDemo for importing into Eclipse
    as depicted), and "Copy projects into workspace" is not checked
  1. Ensure the CreateProjectDirectoryStructure.bat batch file has been executed, that the project has been imported into the Atollic workspace, and that mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to generate the required demo functionality, as noted above.
  3. Select 'Build All' from the IDE's 'Project' menu, the RTOSDemo project should build without any errors or warnings.
  4. After the project has built, click the "Debug" speed button in the IDE to program the microcontroller flash memory, and start a debug session.
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_M4F_Infineon_XMC4500_GCC_Atollic/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
