xTimerStartFromISR
BaseType_t xTimerStartFromISR
TimerHandle_t xTimer,
A version of xTimerStart() that can be called from an interrupt service
routine.
xTimer
The handle of the timer being started/restarted.
The timer service/daemon task spends most
of its time in the Blocked state, waiting for messages to arrive on the timer
command queue. Calling xTimerStartFromISR() writes a message to the timer
command queue, so has the potential to transition the timer service/daemon
task out of the Blocked state. If calling xTimerStartFromISR() causes the
timer service/daemon task to leave the Blocked state, and the timer service/
daemon task has a priority equal to or greater than the currently executing
task (the task that was interrupted), then *pxHigherPriorityTaskWoken will
get set to pdTRUE internally within the xTimerStartFromISR() function. If
xTimerStartFromISR() sets this value to pdTRUE, then a context switch should
be performed before the interrupt exits.
pdFAIL will be returned if the start command could not be sent to
the timer command queue. pdPASS will be returned if the command was
successfully sent to the timer command queue. When the command is actually
processed will depend on the priority of the timer service/daemon task
relative to other tasks in the system, although the timers expiry time is
relative to when xTimerStartFromISR() is actually called. The timer service/daemon
task priority is set by the configTIMER_TASK_PRIORITY configuration constant.
/* This scenario assumes xBacklightTimer has already been created. When a
key is pressed, an LCD back-light is switched on. If 5 seconds pass
without a key being pressed, then the LCD back-light is switched off. In
service routine. */
/* The callback function assigned to the one-shot timer. In this case the
parameter is not used. */
was pressed. Switch off the LCD back-light. */
/* Ensure the LCD back-light is on, then restart the timer that is
key inactivity. This is an interrupt service routine so can only
if( xTimerStartFromISR( xBacklightTimer,
/* The start command was not executed successfully. Take appropriate
action here. */
should be performed. The syntax required to perform a context switch
compiler. Inspect the demos for the port you are using to find the
actual syntax required. */
