AT91SAM3U ARM Cortex-M3 FreeRTOS demo
Using the IAR compiler
The demo application presented on this page is pre-configured to execute on the official SAM3U-EK evaluation kit from Atmel. The demo uses the FreeRTOS IAR ARM Cortex-M3 port and can be compiled and debugged directly from the IAR Embedded Workbench for ARM.
Atmel also provide a comprehensive demo project for their SAM3S-EK evaluation kit that uses the FreeRTOS port. This includes GUI, QTouch, FAT file system and USB functionality.
IMPORTANT! Notes on using the Atmel ARM Cortex-M3 Demo
The IAR workspace file for the SAM3 FreeRTOS demo is called RTOSDemo.eww and is located in the FreeRTOS/Demo/CORTEX_AT91SAM3U256_IAR directory.
The demo application includes an interrupt driven UART test where one task transmits characters that are then received by another task. For correct operation of this functionality a loopback connector must be fitted to the UART1 9 way connector on the evaluation board (pins 2 and 3 must be connected together on the 9 way connector - normally a paper clip is sufficient for this purpose).
  1. Open the FreeRTOS/Demo/CORTEX_AT91SAM3U256_IAR/RTOSDemo.eww project from within the Embedded Workbench IDE.
  3. Connect the host machine (the computer running the IAR IDE) to the target using a J-Link JTAG interface.
  4. Select 'Debug' from the IDE 'Project' menu. The microcontroller flash memory will be programmed with the demo application, and the debugger will break at the start of the main() function.
The demo application creates 33 tasks prior to starting the RTOS scheduler. These tasks consist predominantly of the standard demo application tasks (see the demo application section for details of the individual tasks). Their only purpose is to test the RTOS kernel port and provide a demonstration of how to use the various API functions.
  • LCD task
    This only executes every five seconds. Its main function is to check that all the standard demo tasks are still operational. Should any unexpected behaviour within a demo task be discovered the 'check' function will write an error to the LCD (via the LCD task). If all the demo tasks are executing with their expected behaviour then the check task writes PASS to the LCD (again via the LCD task), as described above. This mechanism can be tested by removing the loopback connector from UART1, and in so doing deliberately generating an error in the COMTest tasks.
  • The 'check' function will write "PASS" to the display every 5 seconds.
  • LEDs D2, D3 and D4 are under the control of the simple 'flash' tasks. Each LED will toggle at a different but fixed frequency.
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_AT91SAM3U256_IAR/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
Unlike most ports, interrupt service routines that cause a context switch have no special requirements and can be written as per the compiler documentation. The macro portEND_SWITCHING_ISR() can be used to request a context switch from within an ISR. An example ISR called vSerialISR() is provided in FreeRTOS/Demo/CORTEX_AT91SAM3U256_IAR/serial/serial.c, this should be used as a reference example.
Source/Portable/MemMang/heap_2.c is included in the ARM Cortex-M3 demo application project to provide the memory allocation required by the real time RTOS kernel. Please refer to the Memory Management section of the API documentation for full information.
