Low Power RTOS Demo - Atmel SAM4L
SAM4L-EK microcontroller evaluation kit from Atmel
The application documented on this page demonstrates how the FreeRTOS tick suppression features can be used to minimise the power consumption of an application running on a SAM4L ARM Cortex-M4 microcontroller from Atmel. The SAM4L is designed specifically for use in applications that require extremely low power consumption.
The demo uses the FreeRTOS GCC ARM Cortex-M3/4 port, the free Atmel Studio 6 IDE, and components of the comprehensive Atmel Software Framework (ASF). The project is pre-configured to run on the SAM4L-EK evaluation kit.
IMPORTANT! Notes on using the FreeRTOS SAM4L demo project
The Atmel Studio 6 Solution file for the ATSAM4L demo application is called FreeRTOS_Demo.atsln, and is located in the FreeRTOS/Demo/CORTEX_M4_ATSAM4L_Atmel_Studio directory.
The demo uses the LEDs built onto the SAM4L-EK and no hardware setup is required.
configCREATE_LOW_POWER_DEMO is a constant that is defined at the top of FreeRTOSConfig.h. The low power demo is created when the project is built with configCREATE_LOW_POWER_DEMO set to 1. A standard kernel only demo (without tick suppression) is created when the project is built with configCREATE_LOW_POWER_DEMO set to 0.
When configCREATE_LOW_POWER_DEMO is set to 1 main() calls main_low_power(). main_low_power() creates a very simple demo as follows:
  • The Rx task blocks on a queue to wait for data, blipping an LED each time data is received (turning it on and then off again) before returning to block on the queue once more. The LED is only blipped on briefly so it does not effect the current reading too much.
  • The Tx task repeatedly enters the Blocked state for 500ms. On exiting the blocked state the Tx task sends a value through the queue to the Rx task (causing the Rx task to exit the blocked state and blip the LED).
For optimum low power results the SAM4L-EK must be connected and powered using only the JTAG USB connector, but the debugger must not be connected (the application must be executed 'stand alone').
The MCU spends most of its time in the Retention low power state (see the implementation section below), during which times the current reading displayed on the board monitor that is built onto the SAM4L-EK will show a low current reading.
Every 500ms the MCU will come out of the low power state to turn the LED on, then return to the low power state for 20ms, before leaving the low power state again to turn the LED off. This will be observed as a rapid blip on the LED every 500ms, and two very brief dots appearing on the graph of current consumption that is displayed by the board monitor that is built onto the SAM4L-EK. The two dots will often be observed as a single dot due to their speed.
Current readings as shown by the board monitor display when the
tickless low power application is executing
The SAM4L microcontroller has several different low power modes. The low power mode that consumes the least energy without loosing the contents of the static RAM and the CPU registers is called Retention mode. The RTOS turns off the tick interrupt and places the SAM4L into its Retention low power state whenever both tasks are in the Blocked state (when only the Idle task is able to execute). Turning the tick interrupt off allows the microcontroller to remain in Retention mode until it is time for a task to leave the Blocked state and execute. If the RTOS tick interrupt was not suppressed in this way the microcontroller would have to exit Retention mode each time a tick interrupt occurred.
The standard RTOS Cortex-M port uses the Cortex-M SysTick timer to generate the RTOS tick interrupt, but the SysTick timer is halted when the SAM4L enters retention mode so it cannot be used in this demo. Instead the RTOS tick is generated by the Asynchronous Timer (AST). The AST continues running in Retention mode, and its full 32-bit width and slow clocking allows the RTOS tick to be suppressed for vastly longer periods than possible when using SysTick.
When configCREATE_LOW_POWER_DEMO is set to 0 main() calls main_full(). main_full() creates a comprehensive test and demo application that demonstrates: The created tasks are from the set of standard demo tasks. Standard demo tasks are used by all FreeRTOS port demo applications. They have no specific functionality, and are created just to demonstrate how to use the FreeRTOS API, and test the RTOS port.
A 'check' software timer is created that periodically inspects the standard demo tasks to ensure all the tasks are functioning as expected. The check software timer's callback function toggles an LED on the SAM4L-EK hardware. This gives visual feedback of the system health. If an LED is toggling every 3 seconds, then the check software timer has not discovered any problems. If the LED is toggling every 200 milliseconds, then the check software timer has discovered a problem in one or more tasks.
  1. Open FreeRTOS/Demo/CORTEX_M4_ATSAM4L_Atmel_Studio/FreeRTOS_Demo.atsln from within the Atmel Studio IDE.
  3. Ensure the target hardware is connected to the host computer through the J-Link USB connector built onto the SAM4L-EK board.
  4. Select 'Build Solution' from the IDE's 'Build' menu, the RTOSDemo project should build without any errors or warnings.
  5. After the build completes, select "Start Debug and Break" from the IDE's Debug menu to program the SAM4L microcontroller flash memory, start a debug session, and have the debugger break on entry into the main() function.
    Two things can prevent the download:
    1. If the SAM4L-EK has not been connected before the J-Link driver might open a window to ask if you want to update the J-Link firmware - but the window (at least at the time of writing) will appear underneath the Atmel Studio 6 window.
    2. The J-Link will default to using JTAG mode, but the SAM4L-EK requires SWD mode as shown below:
      Ensure to use SWD mode
  6. Ensure the debugger is stopped (completely stopped, not just paused) and that the application is free running before taking current readings.
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_M4_ATSAM4L_Atmel_Studio/src/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
The following source code snippet is provided as an example. The interrupt uses a semaphore to synchronise with a task (not shown), and calls portEND_SWITCHING_ISR() to ensure the interrupt returns directly to the task if the task has an equal or higher priority than the interrupted task. See the function USART1_Handler() in the file serial.c included in this demo project for another example.
