Atmel SAM3 RTOS Demo
SAM3 microcontroller from Atmel
This page documents the Atmel Studio 6 IDE RTOS demo application that runs on both the SAM3S and SAM3X ARM Cortex-M3 microcontrollers from Atmel. The demo uses the FreeRTOS GCC ARM Cortex-M3 port, and components of the comprehensive Atmel Software Framework (ASF).
Two pre-configured projects are provided. One runs on the SAM3S-EK2 evaluation kit, and the other on the SAM3X-EK evaluation kit.
IMPORTANT! Notes on using the FreeRTOS SAM3 demo projects
For convenience of distribution, the official FreeRTOS zip file download includes source code files for all the RTOS ports, and all the RTOS demo applications. The projects presented on this page only need a small subset of these files. See the Source Code Organization section for a description of the downloaded files and information on creating a new project.
The Atmel Studio 6 Solution file for the ATSAM3S-EK2 demo application is called RTOSDemo.atsln, and is located in the FreeRTOS/Demo/CORTEX_ATSAM3S-EK2_Atmel_Studio directory.
The Atmel Studio 6 Solution file for the ATSAM3X-EK demo application is also called RTOSDemo.atsln, and is located in the FreeRTOS/Demo/CORTEX_ATSAM3X_Atmel_Studio directory.
The Atmel Studio ARM Cortex-M3 Demo Application
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0 (see the functionality section below), then the demo will include the standard com test tasks. The standard demo com test creates two tasks - a Tx task that sends characters to the USART, and an Rx task that expects to receive every character sent by the Tx task. A loopback connector is required on the USART port for this mechanism to work - simply link pin 2 to pin 3 on the 9 way connector marked "USART" on the SAM3S-EK2 and SAM3X-EK hardware.
It should be noted that the com test tasks are included to demonstrate queues being used to communicate between tasks and interrupts, and to demonstrate a context switch being performed from inside an interrupt service routine. The serial driver used is not intended to represent an efficient implementation. Real applications should make use of the USART's peripheral DMA channel (PDC).
    The queue receive task is implemented by the prvQueueReceiveTask() function in main_blinky.c. It repeatedly reads from the queue with a block time specified, causing it to enter the Blocked state if the queue is empty. The task toggles the red/orange LED each time the value 100 is received from the queue, therefore, because the queue send task sends to the queue every 200 milliseconds, the queue receive task should exit the Blocked state and toggle the red/orange LED every 200 milliseconds.
A 'check' software timer is created that periodically inspects the standard demo tasks to ensure all the tasks are functioning as expected. The check software timer's callback function toggles the green LED on the SAM3 development hardware. This gives visual feedback of the system health. If the green LED is toggling every 3 seconds, then the check software timer has not discovered any problems. If the LED is toggling every 200 milliseconds, then the check software timer has discovered a problem in one or more tasks. This mechanism can be tested by removing the loopback connector, and in so doing, deliberately causing the com test tasks to fail.
CreateProjectDirectoryStructure.bat is located in the same directory that contains the Atmel Studio 6 solution, and must be executed before the demo application can be built successfully.
  2. Open either the FreeRTOS/Demo/CORTEX_ATSAM3S-EK2_Atmel_Studio/RTOSDemo.atsln or FreeRTOS/Demo/CORTEX_ATSAM3X_Atmel_Studio/RTOSDemo.atsln (as appropriate) from within the Atmel Studio IDE.
  5. Select 'Build Solution' from the IDE's 'Build' menu, the RTOSDemo project should build without any errors or warnings.
  6. After the build completes, select "Start Debug and Break" from the IDE's Debug menu to program the SAM3 microcontroller flash memory, start a debug session, and have the debugger break on entry into the main() function.
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_ATSAM3S-EK2_Atmel_Studio/src/FreeRTOSConfig.h or FreeRTOS/Demo/CORTEX_ATSAM3X_Atmel_Studio/src/FreeRTOSConfig.h, depending on the project in use. The constants defined in this file can be edited to suit your application. In particular -
    Whereas configKERNEL_INTERRUPT_PRIORITY and configMAX_SYSCALL_INTERRUPT_PRIORITY are full eight bit shifted values, defined to be used as raw numbers directly in the ARM Cortex-M3 NVIC registers, configLIBRARY_LOWEST_INTERRUPT_PRIORITY and configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY are equivalents that are defined using just the 4 priority bits implemented in the SAM3 NVIC. These values are provided because the CMSIS library function NVIC_SetPriority() requires the un-shifted 4 bit format.
The lowest priority on a ARM Cortex-M core is in fact 255 - however different ARM Cortex-M microcontroller manufacturers implement a different number of priority bits and supply library functions that expect priorities to be specified in different ways. For example, on Atmel SAM3 ARM Cortex-M3 microcontrollers, the lowest priority you can specify is in fact 15 - this is defined by the constant configLIBRARY_LOWEST_INTERRUPT_PRIORITY in FreeRTOSConfig.h. The highest priority that can be assigned is always zero.
